coil wire set up - NCRS Discussion Boards
coil wire set up
+ More Options
Posts
  • Richard C.
    • July 31, 2001
    • 144
    coil wire set up
    i am going to put my 74 back to stock set up w points. does annybody have a pick w the coil wire set up? and did they have a ballist in line?
    Re: coil wire set up
    Richard -
    Ballast resistors weren't used after 1967 - the cloth-covered ignition wire from the bulkhead connector to the coil (+) terminal was a resistance wire, and that spade terminal also had a wire (yellow, I think) crimped in it from the starter solenoid "R" terminal to provide a full 12V when cranking. The coil (-) terminal has the black wire (from the points) from the distributor.
    If you have a radio, the coil (+) terminal will also have a spade from the radio noise suppression capacitor on it.
    • Christopher K.
      • September 10, 2007
      • 311
      First of all, John you have been a invaluable source of information for me during my restoration. Your articles and posts are extremely helpful. On my original '73 L82 there seems to be a slight difference from your description.
      I have a black wire with "resistance" written in pink letters. Doc Rebuild shows this on his diagram also. This wire is crimped together with a cloth wire which is red, not yellow. These both go to the + side of the coil. (The red cloth wire goes to the R terminal on the starter at the other end as it should)
      When I first researched this in the archives I found a few members that also had the "red" wire. Perhaps your '74 is set up the same way.
      Chris
      Chris
      '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
      '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
      • Tom H.
        • December 1, 1993
        • 3440
        Hi Chris
        The cloth wrapped wire on my 14000 mile 73 L48 is yellow.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Richard C.
          • July 31, 2001
          • 144
          i knew somebody would help!!!!! THANKS under the cloth coverd wire is pink or red along with a black wire together i will take a look at the starter mtr R term to see if there is a wire there how manny volts should there be at the pos side of the coil with ket on mtr not running?
          • Christopher K.
            • 311
            Tom, just curious, what is your build date on your '73? Mine is Mar 15.
            Richard, with key on run the volts should be 6-8 volts through the resistance wire. During start, a full 12 volts comes through the purple wire on the S terminal.
            Chris
            Chris
            • Tom H.
              • December 1, 1993
              • 3440
              Chris
              Chris !!
              Been so long I forgot ! Had to go out and look. Jan 04 is trim tag date.
              Tom
              Tom Hendricks
