upper control arm studs and nut finishes - NCRS Discussion Boards
  • Ned T.
    • December 29, 2008
    • 188
    Can anyone tell me what finish is on the upper control arm studs and nuts on 69. They are very visible and would like to get them right.
    Thanks, Ned
  • Craig O.
    • July 31, 1983
    • 207
    Re: upper control arm studs and nut finishes
    If I understand your question, the 4 knurled shank studs, 2 on each side that attach, (pressed) to the frame and pass through the upper control arm shaft are black, or dark dark gray phosphate with a silver cad or zinc torque lock nut.
    • Ned T.
      • December 29, 2008
      • 188
      Craig, Yes that is what Im talking about. Thank you for the information. Ill be installing them tomorrow.
      Ned
