Rochester Carb Throttle Bracket - NCRS Discussion Boards
  • Mark A.
    • February 1, 1996
    • 299
    I am missing the throttle cable mounting bracket that mounts on the driver side rear of my Rochester carb on my 69 390 hp. Does anyone have one for sale? Paragon apparently is not making it anymore. Thanks, Mark
    • 43273
    Re: Rochester Carb Throttle Bracket
    Mark-----
    Have you checked with Dr. Rebuild? They might still have some NOS examples.
    • Mark A.
      • February 1, 1996
      • 299
      Joe,
      I haven't. I will check tommorow. Thanks for the tip. Mark
      • Kenneth B.
        • August 31, 1984
        • 2091
        MARK
        I have one if you can't find one. I will be gone till 4/8/09. Please email me if you don't get one by then.
        KEN BARRY
        • Jeffrey A.
          • October 22, 2006
          • 273
          mark
          Is your car have a/c? If so I was wondering if you had a picture of your
          Idle solenoid bracket you could post or email me. I am missing mine
          Jeff
          • Jeffrey S.
            • May 31, 1988
            • 1898
            Jeff:
            What engine do you have? Not all '69 A/C cars had a solenoid or bracket. Yours may be missing because it never had one. Just a thought.
            Jeff
            • Jeffrey A.
              • October 22, 2006
              • 273
              Jeff
              Mine is a 68 427/390 (L36) with A/C and its a 4 speed. The assembly manual shows it should have one. It would make my day if I did not this bracket, but with my luck I will. Thanks
              • Pat K.
                • November 1, 2003
                • 351
                Jeff,
                Good luck finding that solenoid bracket. For two years I scoured Carlisle, plus dozens of phone calls, no luck. I believe these were just routinely thrown in garbage.
                Pat
                • Jeffrey A.
                  • October 22, 2006
                  • 273
                  Pat
                  That seem to be the consensus from everyone on this item . You can get the one for the 400hp engine its a exact repop for $1,500.00. I have a lot of differnt items to complete in the meantime. I will just put it on the back burner with a couple of other items I have been looking for. Not the end of the world, especially for $1,500.00. Thanks
