Factory engine testing? - NCRS Discussion Boards
  • Edward C.
    • March 1, 1985
    • 125
    Were the high performance engines for regular production in the late 60's and early 70's get bench tested at the engine assembly plants? Thanks Ed
    • 43212
    Re: Factory engine testing?
    Edward-----
    All PRODUCTION engines were test-fired on natural gas prior to shipment to the vehicle assembly plants in the 50's as well as today. Most, but not all, COMPLETE SERVICE engines were also so-test-fired.
    • Tom H.
      • December 1, 1993
      • 3440
      Edward-----
      Good info, Joe
      How long would a "test fire" be. Was there an extended break in time, or just enough to be sure it lit and didn't make unusual noises ?
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
        • 43212
        Originally posted by Tom Hendricks (23758)
        Good info, Joe
        Tom-----
        It was/is a relatively short test. I think about 5 minutes.
        • Tom H.
          • December 1, 1993
          • 3440
          Tom-----
          That is neat to know. I always wondered about that. Was there someone assigned to this area to make adjustments or final tuning to these engines during run in ?
          Tom Hendricks
            • 43212
            Tom-----
            Yes, there was. I don't think there was a worker for each engine, but there was definitely a worker present for each group of engines. For some engines, final balancing was done at this time. This included, at least, all C4 era LT1 and LT4 engines as well as many 87+ Gen I small blocks.
            • Tom H.
              • December 1, 1993
              • 3440
              Tom-----
              Thanks for the info, Joe. Appreciate it !
              Tom Hendricks
              • Clem Z.
                • January 1, 2006
                • 9427
                the new corvette engine are not started at the factory as they are only spun with a electric motor to makes sure it has oil pressure and to check that all other items work properly.
                • Steven B.
                  • June 30, 1982
                  • 3985
                  Edward-----
                  Joe, why natural gas?
                  Thanks!
                  Steve
                    • 15662
                    I think the hot fire test only lasted about 30-60 seconds. (John Hinckley knows.) Consider that Chevrolet was manufacturing about 5000 engines per day for all product lines. The initial timing was set, oil pressure observed, and the running engine was inspected for coolant and oil leaks and abnormal noise.
                    An adapter plate was lowered to the manifold flange to feed a premix of natural gas and air. This is much easier/safer to do than installing the carburetor and filling the bowls to do a "wet" test.
                    The engine configuration as tested was essentially a "long block" with the ignition system, inlet and exhaust manifolds added.
                    Engines were shipped to the plant in this configuration - less carburetors, and other front end accessories and integration hardware, which were installed at St. Louis before the engine was installed in the chassis.
                      • 15596
                      I wish I could remember how long they "hot fired" the engines, but I think Duke has it about right. I remember at Flint they said they ran the Corvette engines longer, but again I can't recall how long. Maybe like 2 minutes. John Hinkley will have a better handle on this than I do.
                      During "hot fire they listened for knocks, set the distributor initial timing, and tested the balance and either added or took away (drilled) weight from the flywheel/flex plate and harmonic damper.
                      For the current engines (at least for 2008) the Wixom built engines are "hot fired" on natural gas, and the balance is set at that time -- no more setting the ignition timing though. The Canadian built engines are NOT "hot fired" any longer.
                        • 43212
                        Thanks!
                        Steve
                        Steve-----
                        I think it was a matter of manufacturing convenience as well as keeping the engines as "new appearing" as possible.
                        • Bill M.
                          • April 1, 1977
                          • 1386
                          I worked the summer of '69 at Tonawanda. Duke and Terry have it right.
                          Ed, if you're asking if the engines were tested for power, the answer is no. We did test some engines for durability. They were run for 200 hours at mostly full throttle. Very few had problems. One dynamometer ran small blocks and one ran big-blocks.
                          Even the ZL1s were not tested for performance!
                            • 15596
                            When I toured Tonawanda the employees, a few of whom claimed they worked there in the late 1960s, said they ran L88s on the dyno. It wasn't clear if their claim was that ALL were dyno run, or just some. The stories focused on the power output and noise from the roof-vented exhaust.
                            • Bill M.
                              • April 1, 1977
                              • 1386
                              Hi Terry:
                              I remember your article from the Restorer; brought back fond memories. I remember you talked to Reed Johnson. He was one of the guys I worked with that summer of '69 in the dyno. lab. We ran L-88s with tubular headers and huge mufflers that vented through the roof. I could hear them running as I walked home; very sweet sound. All other engines we tested that summer ran through an exhaust system that ran under the floor; very quiet. The L-88s we ran (definitely not all!) were run for 200 hours for durability. The engines were run from peak torque to peak horsepower, so power was "measured", but it was incidental to the purpose of the test. I remember seeing a power curve from the Mark IV dyno cell that showed an L-88 putting out 560 HP. I remember from your article that Reed said they put out 430. The headers and big mufflers were installed the summer of '69, so maybe he remembered the 430 from earlier testing through the restrictive exhaust...or he gave a politically correct corporate answer. Anyway, I saw 560 on the dyno. Unfortunately, we didn't test a ZL-1 that summer.
                              Bill
                              I thought I should add that we never shipped an engine that ran on the Tonawanda dyno to an assembly plant. If the engine had a small problem (broken valve spring, burned rocker ball), we fixed it and kept testing to 200 hours. If it suffered a major problem (a broken piston would trash every thing except the opposite bank's cylinder head), the test was terminated. All dyno. engines were torn down and the parts mounted on display boards for the component engineers to examine, and then all the parts were scrapped.
