1971 Which Rear End Tag???? - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    Which red tag goes on a January 1971 built 71 LT-1. Use Limited Slip Diff Lubricant Only OR Use Positraction Diff Lube Only???? Which one???
  • Kenneth T.
    • March 23, 2008
    • 631
    Re: 1971 Which Rear End Tag????
    Paul,
    If you don't get a reply, which I doubt, I will look at mine tomorrow night. Too late for me start crawling around under it tonight.
    • Kenneth T.
      • March 23, 2008
      • 631
      Looked at an old picture of mine, July build '71 "Use Positraction Diff Lube"
      • Warren F.
        • December 1, 1987
        • 1516
        Paul,
        March & April built '71's have the 'Use Limited Slip' verbage.
          • 15632
          Be careful -- it may have to do more with the ratio than with the build date. I'm not sure, either way, but check BOTH the date and ratio if you want to sort it out.
            • 3418
            Hi Paul,
            My Jan 71 built #6589, has a 3:36 ratio and has a tag with the 'limited slip' wording. It's quite dark red and the lettering width is VERY thin.
