My friend told me once there are some essential tools needed in the garage. I good vice, a bench grinder, jack, jack stands, and good work benches. There are other tools and items. My question focuses on three items. The Vice, the bench grinder and a shop-vac. what size, make/model are good. I have no vice or bench grinder, and I'm catching heat for using the Kirby in the garage.
Todd
Todd
Mine is a Delta variable speed and I really like that feature a lot. Have a large Rigid shop vac from Home Depot for years, used quite a lot and very happy with it. Have a Sears 4" vice which has taken a lot of pounding, welding heat, you name the abuse for years. Those are things I have had good luck with. I have often made the mistake of buying a tool that turns out too small or underpowered. Don't underestimate your needs as I have found the next project is always bigger than the last one.
