Found a correct 63 rear spring - now what? - NCRS Discussion Boards
  • Jeff A.
    • January 1, 2000
    • 312
    OK - I finally secured an original 1963 rear leaf spring.
    How do I tell if it needs to be rebuilt, or if I can just bolt it on?
    My Cars
  • Harry S.
    • July 31, 2002
    • 5342
    Re: Found a correct 63 rear spring - now what?
    Post a picture please.
    • Jeff A.
      • January 1, 2000
      • 312
      Harry - I knew you would say that.
      It has been in a warehouse for years - a little muddy, but not very rusty.
      came from a very reliable source.
      My Cars
      • Harry S.
        • July 31, 2002
        • 5342
        Jeff, you could probably just bolt it on and go. What does the rest of the chassis look like. If it's neat and clean with no surface rust then I would redo the spring.
        • Jeff A.
          • January 1, 2000
          • 312
          The look was not what I was concerned about.
          Absolutely, I am going to clean it up and make it look nice.
          I would hate to install it, then find out I should have had it re-arched or something. I was wondering if there was a way to tell if it was still going to be "springy"
          More worried about functionality.
          My Cars
          • Harry S.
            • July 31, 2002
            • 5342
            Can't help with that part. Hopefully others will chime in.
              So, measure the arch and compare to spec to determine if it needs to be re-arched...
              Don't know how to measure free arch? Lay the spring flat on its side. Draw a chord though the center of the end holes. Measure from the center of the chord to the bottom of the spring above.
              Factory spec is free arch = 10.0"
              • Harry S.
                • July 31, 2002
                • 5342
                Jack, is the measurement done with the spring assembled or part? I believe the characteristics of that bottom leaf change when assembled.
                  Measure with the spring assembled but NOT under tension, Harry.
                  • Harry S.
                    • July 31, 2002
                    • 5342
                    Just measure mine, I get 10.0 when the string is laid at the bottom of the holes not dead center.
                    • Joel T.
                      • April 30, 2005
                      • 765
                      Jeff;
                      I have a '63 with what must be a replacement spring... Mine has 7 leaves versus the standard 9 (as in your pictures). How did you determine that it was an original 1963 spring??
                      Thanks.
                      Joel
                      • Jeff A.
                        • January 1, 2000
                        • 312
                        I think Harry should answer that.
                        He guided me in the right direction during my pursuit.
                        In 63 the only model that received the 7 leaf was the Z06.
                        In 64 I believe you would get it also with the F41 option.
                        Will measure my spring when I get home tonight. Thanks for the info!!!
                        My Cars
                          • 15706
                          It's very easy to disassemble the spring - inspect the liners and inspect the leaves for corrosion.
                          Likely a new set of liners is in order if they are worn (likely) and you can at your option treat the leaves to an anti-corrosion coating if you're not concerned about loosing a few judging points.
                          Install it with new set of spring link cushions.
                          • Stan E.
                            • April 30, 1991
                            • 383
                            I think the leaves were painted gray and the repo linners will be a deduct.
                            • Jeff A.
                              • January 1, 2000
                              • 312
                              the springs were natural or black in 63.
                              Are the repro liners really different in appearance?
                              My Cars
