Late 69 Differential Code Stampings - NCRS Discussion Boards
  • Jamie F.
    • May 20, 2008
    • 337
    Most of the differential stampings I have seen start with a 1 or 2 (which I think was the shift) and end with a W (for Warren the factory that built it). My stamping has neither of these.
    It just has the axle code and date of AZ 10 22 69, and a casting date of I 10 69. Trim tag date is P20.
    Has anyone seen this?
    I was told that some late '69 were not built at Warren and that might explain the lack of the last factory stamp letter?
    Another said that there was a transition to the 70 three letter code and the stampings procedure changed?
    Anyone else with a Nov '69 car that could let me know what theirs says?
    Any experience in these stampings would be appreciated.
    Thanks!
  • Harry S.
    • July 31, 2002
    • 5349
    Re: Late 69 Differential Code Stampings
    Jamie, I just picked up a 69 differential as I needed the posi. unit. The stamp is 2 AO 4 24 69 W That translates to a 3.70 rear. Hope that helps.
    • Jamie F.
      • May 20, 2008
      • 337
      Harry,
      That's exactly my point. Your April 69 Diff has the 2 and the W, mine doesn't. But is was made 6 months later. Just wondering if mine is correct or not without those two characters.
      Thanks for the input.
      • Harry S.
        • July 31, 2002
        • 5349
        If it was 6 months later I believe the differential is for the 1970 model year. Was that stamp pattern different?
        • Jamie F.
          • May 20, 2008
          • 337
          '70 codes were 3 letters. Mine is still a '69 code or AZ. I would just like to know if the absence of the 1 and the W is a normal thing or not???
          Could the rear have been made somewhere else than Warren?
          What other locations built Diffs?
          • Harry S.
            • July 31, 2002
            • 5349
            The other plant codes are G B and K
            I just have to ask, is there a C infront of the AZ
            • Jamie F.
              • May 20, 2008
              • 337
              Harry,
              No C.
              Just AZ 10 22 69. Which is October 22 1969.
              Which c[FONT='Calibri','sans-serif']oincidentally[/FONT] most of the parts on my car are that date for some reason; Block, Heads, Distributor, Exhaust manifolds, ALL J22.
              Strange.
              • Lawrence M.
                • February 1, 1995
                • 404
                Jamie, my old '69 now long gone to a new owner had a Q 15 body build date. The diff code was 1C AN 12 3 69 W. The W stamping was very faint. I have the casting code written down somewhere, but I can't find that piece of paper right now. Hope this helps you.
                Larry
                Larry
                2002 Z51 Convertible
                1969 L46 Convertible
                • Tom M.
                  • 716
                  here is my late 69
                  • Jamie F.
                    • May 20, 2008
                    • 337
                    Tom,
                    Do you know the casting date of your diff case?
                    • Harry S.
                      • July 31, 2002
                      • 5349
                      Tom's looks like CFA to me.
                      • Jamie F.
                        • May 20, 2008
                        • 337
                        Yes Harry that's a '70 code which was used on late '69 according to the Guide and other info.
                        My Diff is about a month later, but doesn't carry the "C" or the "W". Just trying to understand why.
                        I figure someone else must have come across this too. My best guess is that it was made a a different plant than W, Warren???
                        • Gary R.
                          • April 1, 1989
                          • 1808
                          I have a I 19 9 cast dated Diff with 2CAM121769W stamped in it. It has the original gears, dated 6/69. This came out of a late 69 many years ago. I've had it on my shelf for 25 years.
                          • Jamie F.
                            • May 20, 2008
                            • 337
                            Gary, interesting that you case was cast just 9 days after mine, but was assembled almost 2 months after mine. It would be interesting to see when Tom's was cast vs. his assembly date.
                            • Tom M.
                              • 716
                              Originally posted by Jamie Fiffles (49040)
                              Tom,
                              I will check
