Making Bilstein Shocks Look Like Delcos - NCRS Discussion Boards
+ More Options
Posts
  • Paul C.
    • November 12, 2007
    • 511
    I have a 71 and have Bilstein shocks--love them. For judging purposes it was stated I could just paint them grey and get most of the points. Can someone tell me which paint and color would be the best match for front and rear. The judging manual says front shocks==blue grey and rear shocks==primer grey. Where to get the paint. Should any other numbers or tags be put on them or just paint them grey. Thank you as always for your help.
    Paul
    • 43232
    Re: Making Bilstein Shocks Look Like Delcos
    Paul
    Paul-----
    I'd use Quanta's shock paint on BOTH the front and rear shocks. Actually, the configuration of some of the Bilstein shocks is not that much different than the CURRENT Delco shocks (although they are quite a bit more expensive).
      • 15605
      Paul,
      The 1970-72 judging manual really says they are two different shades of paint? Would you mind telling us what page that is on, and giving us a quote, please?
      • Jeff G.
        • October 25, 2006
        • 187
        Terry read my mind. That sounded way off target about the colors. I've discovered 4 errors (so far) in the 68-69 manual. Better to be safe and consult this tech board before redoing any surfaces.
          • 15605
          Jeff -- If you only found four I would bet you missed some. Be sure to send them to the team Leader -- contacts button above or the second page of The Restorer -- and to Dick Whittington.
          • Doug J.
            • April 1, 2005
            • 140
            Paul, The picture should clear that up. "Shocks were Delco, semi-gloss grayish blue in color" I would imagine "Shocks" meant all four.
            The rear spring was "light gray primer".
            • Paul C.
              • November 12, 2007
              • 511
              Terry I was wrong and misread the manual--it does not say two colors. It says blue grey color on page 105. My error.
              Paul
                • 15605
                Thanks Paul. I won't go into the many ways something can get fouled up in the manual, but we do try our best to get it right or correct it. I wanted a chance at the latter.
                • Paul C.
                  • November 12, 2007
                  • 511
                  When you painted the bilsteins did you primer them first or just shoot the grey over the yellow? Just wondered how well it adhered and did it stick to the plastic sleeves on the rear shocks? Thanks again. Paul
                  • Chris F.
                    • April 1, 2006
                    • 23
                    Good reading on the paint color, I intend to do that to mine when they are shipped out. I have seen the color and have a fair idea of what it looks like however would there be a paint code to mix to.
                    • Paul C.
                      • November 12, 2007
                      • 511
                      I ordered the Quanta shock grey color. I see paragon selling stickers that go on the front and rear shocks--EK front and EM rear---are these necessary--I don't see them mentioned in the judging manual.
                      • Kenneth T.
                        • March 23, 2008
                        • 631
                        Pual,
                        I agree on the bilstein, dumped my kybs. The profile on them is very close to the original delco. My '71 calls for labels VS front and DG rear though.
                        Who is correct? I am not sure.
                        Ken
                        • Paul C.
                          • November 12, 2007
                          • 511
                          Ken:
                          I agree judging manual states DG--front and VS---rear?????
                          • Kenneth T.
                            • March 23, 2008
                            • 631
                            Ken:
                            Dislexia on my part DG front VS rear
                            • Doug J.
                              • April 1, 2005
                              • 140
                              Ken,
                              Go with the VS and DG for standard suspension on the 71'. Corvette Central has them.
