Here's All The Dates on My 67 Corvette Components I Could Find - NCRS Discussion Boards
+ More Options
Posts
  • Kirk M.
    • June 30, 2006
    • 1036
    Here is a list of all the dated components on my car. Kinda interesting to look through all the parts and dates. Hope to find more!
    Various Dated Parts in the Production of Corvette #16,469
    right vent glass April 1966 (GA)
    intake casting date May 24, 1966 (E246)
    interior trim panel August 7, 1966
    overflow tank November, 1966 (66K)
    voltage regulator December, 1966 (6M)
    alternator December 15, 1966 (6M15)
    driver's side mirror January 1967 (1DMI7)
    left vent glass January 1967 (NZ)
    windshield February 1967 (XZ)
    right side window February 1967 (XZ)
    left side window February 1967 (XZ)
    Holley carburetor February 1967 (723)
    Low note horn February 2, 1967 (7C2)
    starter February 7, 1967 (7B7)
    clock February 20, 1967 (0517)
    passenger seat belt March 6-10, 1967 (10E67)
    engine casting date March 8, 1967 (C87)
    engine assembly March 10, 1967 (V03I0HO)
    spare tire tub door March 17, 1967
    distributor band March 23, 1967 (7C23)
    dash cluster March 27, 1967
    radiator April, 1967 (67D)
    body build (A.O. Smith) April 3, 1967 (A-2731)
    spare tire tub April 5, 1967
    powerglide transmission April 9, 1967 (7D09)
    rear axle April 11, 1967 (4 11 67)
    car was built on April 18, 1967 (16,469)
    Kirk
  • Gene M.
    • April 1, 1985
    • 4232
    Re: Here's All The Dates on My 67 Corvette Components I Could Find
    Kirk,
    This is very well thought out. Having all the dates on one's car is cool. Now my question.......Do you have photos of all those dates? That would be even cooler!
    • Kirk M.
      • June 30, 2006
      • 1036
      Gene,
      I have a few pics. Not a bad idea though. Although some things I noted when items were removed and restored, and the actual dates may not now be visible. Need to keep that camera handy.
      Was just wondering if anyone else had such a list and we could compare. I have gotten some earlier feedback on window dates and such to suggest that there might actually be some patterns here. Let me know what you got. Thanks.
      Kirk
      • Stephen L.
        • May 31, 1984
        • 3162
        This is a list I made for my 67.
        I've also a large book of photos and paperwork.. before and after shots of many many pieces of the car.
        • Kirk M.
          • June 30, 2006
          • 1036
          Stephen,
          Am I reading correct that your car was built April 10? If so, that is close to my April 18th build date. Should be an interesting comparison. I have printed your document out and plan to cross-reference. One thing that jumps out at me is the August 66 glass all-around. That makes my passenger vent glass seem not so far off the mark, although April 66 seems a bit "old", but it clearly doesn't make sense as a replacement piece. Thanks.
          Kirk
          • Henry S.
            • April 30, 2005
            • 816
            Kirk and Stephen,
            You both did a heck of a job putting together your list of dated parts. Anyone getting ready to do a restoration needs to make note of that and be sure to take TONS of pictures. I finished my 67 last year and wished I'd thought of putting a list together like that. That was the first restoration I ever did and I learned so much from guys here on the forum. Looking at all those parts spread out over the shop floor can get pretty overwhelming. I think I only ended up with one part left which I thought was pretty good. Although I must admit I was pretty goofy by the time I was finished.
            Shooter
            • Stephen L.
              • May 31, 1984
              • 3162
              Originally posted by Kirk McHugh (46057)
              Stephen,
              Kirk
              You read it correctly. I have a local 67 owner aquaintance whose car is within 300 serial numbers. It is a small block Marina Blue coupe.... GREAT COLOR choice I might add..... April was a good month
              • Kirk M.
                • June 30, 2006
                • 1036
                Yes it was, although mine is ermine white. Seems to me that they used the parts they had in the bins, which probably explains the 66 glass dates. Thanks for posting all your information.
                Kirk
                • Mike E.
                  • February 28, 1975
                  • 5141
                  Here's all the dates I have so far on a Goodwood green/ saddle 67 convertible:
                  As per the tank sticker, it is a base motor, 4 speed, California K19, telescopic column, tinted glass all around, speedminder, headrests, C08 hardtop, M20, 3.36posi, black vinyl top, blackwalls
                  Block stamping V0501HH
                  Intake L186
                  heads D57
                  Tranny P7E04
                  Differential AM 4 12 67
                  Flywheel D21 7
                  Radiator D 67
                  Expansion tank D 67
                  Distributor 7C27
                  Build date J03 A-3569 (AO Smith car)
                  Windsheidl, rt. vent and rt. window VA (Dec 66)
                  left vent and left window NZ (Jan. 67)
                  Voltage regulator 7E
                  Horns 7C1 and 7C2
                  Hardtop rear window DG (April 67)
                  Headlight motors 3A67 4B67
                  Fan clutch CJ B13H
                  Fan blade D
                  Telescopic column D
                  Hazard flasher 8 0 7
                  Spare tire tub March 28, 1967
                  Left Door panel April 6, 1967
                  rt. door panel March 27, 1967
                  That's what I have so far. I hope that helps add to the database.
                  Mike
                  Last edited by Mike E.; February 25, 2009, 03:02 PM. Reason: forgot a couple of dates
                  • Kirk M.
                    • June 30, 2006
                    • 1036
                    Mike,
                    What is your car #? VIN if you don't mind. Thanks.
                    Kirk
                    • Mike E.
                      • February 28, 1975
                      • 5141
                      Sorry about that--18621--had that in the block stamping info and then took it out because I thought it was superfluous. That's what I get for thinking!
                      • Mike E.
                        • February 28, 1975
                        • 5141
                        Kirk especially--
                        A couple more dates off 18621:
                        Starter--7 C 15
                        Left outboard headlight 52 7 2 (May 2nd)
                        Left inboard headlight 41 7 22 (April 22nd)
                        Mike
                        • Rich P.
                          • January 12, 2009
                          • 1361
                          Don't forget the date on your blower motor.
                          Rich
                          • Curt C.
                            • May 31, 2000
                            • 49
                            Rich, how do you find the date on the blower motor? Do you have to remove it to see it? Thanks.
                            • Rich P.
                              • January 12, 2009
                              • 1361
                              Curt,
                              no you can see it in the car. It is on the flat where the bolts that secure it to the heater box go. Simple date. 6-67 would be June 1967.
                              Rich
