Engine Production Stamping - NCRS Discussion Boards
  • Brad H.
    • January 27, 2009
    • 250
    I have a question concerning engine stamping. I bought a 69 several years ago which did not have the original engine installed in it but it came with a torn down engine which was supposed to have been the original. It has the correct VIN stamping but the engine production stamp is my question. The stamp is fairly easy to read and apppears to be: VI0I5HZ. While I understand the V is for Flint and the HZ is for the 350/300 Automatic I am confused on the numbers/letters of the build date. Did Chevrolet use the symbol I instead of the numeral 1? If I interpret this production stamp as if it were numbers instead of leters it matches. My car was built Nov 5 of 1969 and this production stamp would be Flint engine build date October 15.
    Simplified then my question is this: Did they use the letter I for the number 1?
    Brad Hood
    • 11643
    Re: Engine Production Stamping
    Yes.
    The use of "I" in place of the numeral "1" is well documented.
    Check out this one - two different 1's.
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11323
      Yes Brad....I=1, e.g. Below is Feb 18. Sounds like your 350 has the right assembly date to me. What is the block cast date?
      Rich
        • 15599
        Yes.
        And note the square O also.
