72 Coupe Speaker Question - NCRS Discussion Boards
    • 6950
    Can A 4 Ohm Speaker Be Used With The Factory System W/o Any Probelms Or Damaging The Radio. Thanks Ed
  • Tom H.
    • December 1, 1993
    • 3440
    Re: 72 Coupe Speaker Question
    I think most of the die hards will suggest against using the 4 ohm speakers. Many advise that it is hard on the transistor / amp. It can cause it to overheat.
    I am no expert and am sure one will chime in with better advise.
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
      • 11668
      Ed,
      There are brand new 10 ohm speakers available through GM, so I wouldn't see a need to use 4 ohm speakers. In theory, you "could" use them but you're much better off with new ones or to have your originals "reconed."
      Patrick
        Agree! The design center was for 10 ohm speakers. Substituting an 8 ohm speaker (very common) gets you so close to the design center, there's little, if any, affect. But, dropping down to 4 ohms is wandering a bit too far off design center in my opinion...
          • 6950
          Thanks For The Replys Guys, Its 10 Ohms Only.
            Bare in mind that if you're considering the use of aftermarket versus original or GM service replacement speakers, it's going to be hard to find off-the-shelf 10-ohm units... Most of what's sold in substantial quantity today come in 4, 8, or 16 ohm nominal formats...
              • 6950
              Thanks Jack- Awhile Ago I Took Out A Aftermarket Radio From Under Dash, And Removed The Speakers,they Were 4 Ohms, Now I Need To Replace W/ Correct I Guess. I Was Thinking The 4 Ohm Speakers Might Work.
