Replacing Fuel lines on 1970 - NCRS Discussion Boards
  • Steve G.
    • December 12, 2008
    • 192
    Anyone know if its possible to change the steel fuel supply and return lines on a 1970 without taking the body off the frame? Steve
  • Michael G.
    • March 2, 2008
    • 487
    Re: Replacing Fuel lines on 1970
    I left you a PM. Will continue tomorrow afternoon. Mike
    • Doug J.
      • April 1, 2005
      • 140
      Mike, If you have an answer and a fairly easy way of replacing the lines, please let me know also. I was contemplating replacing those two lines also, but everytime I look under there and see the way it is routed I turn away. Car has a 4spd, crossmember is welded.
      • Warren F.
        • December 1, 1987
        • 1516
        I'd be interested in knowing as well. One of my cars could use replacing of those steel lines.
          • 11698
          We had a thread on this not long ago.
          The short answer: yes, it is possible, but it is tough. Take your time and you can do it.
          https://www.forums.ncrs.org/showthre...+fuel&uid=3554
