402 BBC rod problems - NCRS Discussion Boards
  • Paul D.
    • January 1, 1988
    • 101
    Maybe off Corvettes,I have a '70 402 #3909854 block for my '70 Nova SS. I ordered a kit from Calif to rebuild the block.Anyway I have 7/16" rod bolts and they are hitting the pass side of the block in a big way.I had this assy balanced and would like to use it as is.The 7/16" rods/bolts are bigger and about .220 longer than the std 3/8" rods that I have off an old 454.The crank is the 6223 396 crank and I'm using KB pistons. My question is: how much meat is on the bottom of the cyl wall before I have a problem? Do I need to use the 454 3/8" rods. I have a die grinder,but all 8 rods/block will have to be worked.I need to remove about 1/4" or so on the block.........
    • 43289
    Re: 402 BBC rod problems
    Paul-----
    I think you mean GM casting #3969854. This is the 1970 402 block. There never was a block of GM #3909854.
    As far as the rod bolt interference goes, no Chevrolet 396, 402, or 427 was ever manufactured with 7/16" rod bolts EXCEPT 1969 L-88/ZL-1. So, no 402 block was ever designed to accommodate rods with such bolts. Notwithstanding that, I believe that most 396, 402, and 427 blocks can be clearanced to accommodate rods with 7/16" bolts. However, it may depend on the rods being used. If you're talking about GM rods with 7/16" bolts, I think it can be done. As far as other rods, I'm not sure.
    We'll need clem to weigh in on this one. I'm sure he's been "down this road".
    • Clem Z.
      • January 1, 2006
      • 9427
      Paul-----
      you must have aftermarket rods i would think as i never saw any problem using GM BBC rods with 7/16" bolts. i must admit i never used the GM 7/16" rod bolt rods in a bore smaller than 4.250. i have had to clearance early blocks when using a 4" 454 crank but not the amount you are referring to. are these cap screw rods not the thru bolt like the stock GM BBC rods ?
      • Richard F.
        • May 31, 1986
        • 193
        I had to grind a little on my 5439 block when I went to 7/16. Wasn't much but it was most necessary.
        • Paul D.
          • January 1, 1988
          • 101
          The rods are after market with standard 7/16" ARP bolts in them. I can take a little of the bolt after installation,but I would rather cut on the block if possible.I was trying to assemble an engine for the Nova and thought that a kit would be easier as I had no internals for the 402.Joe is right the block is 3969854,I was was bummed today as I was engine building until I hung #1 and #2 piston in the hole and tried to move crank.How far up in the cylinder can I safely notch?.....I can see a very little of the botton skirt of the piston when it is at BDC........
          • Clem Z.
            • January 1, 2006
            • 9427
            i would contact the people who sold you the kit as i would guess that problem has come up before
