Oil Pan 69 427 - NCRS Discussion Boards
Oil Pan 69 427
  • Ned T.
    • December 29, 2008
    • 188
    Oil Pan 69 427
    What supplier can I buy a new oil pan from that is as close to original as possible. I ordered one from Paragon but they since discontinued it.
  • Don W.
    • September 30, 1997
    • 492
    Re: Oil Pan 69 427
    Dr Rebuild
    Steel Oil Pans
    57-62 Oil
    Pan 4 qt. China replacement repro
    63-68 Oil
    Pan 327 except Sp Hiper, FI or
    69-74 Oil
    Pan 350 except Sp Hiper or
    75-79 Oil
    Pan 350 1426206 79.95
    63-74 Oil
    Pan 327 except SpHiper, FI, or
    5 qt. China
    authentic repro 1426207 275.00
    62-65 Oil
    Pan with Sp Hiper, FI, or
    69-72 Oil
    Pan with Sp Hiper genuine GM 1426210 450.00
    65-74 Oil
    Pan with 396, 427, 454 GM 1426212 179.00
    65-74 Oil
    Pan with 396, 427, 454 China 1426208 89.95
    75-79 Oil
    Pan with L-48 350 1426214 148.00
    75-79 Oil
    Pan with L-82 350 1426215 134.75
    80-82 Oil Pan NOS 1426216 325.00
    • Pat K.
      • November 1, 2003
      • 351
      Re: Oil Pan 69 427
      Maybe wait for Carlisle
      • Dick W.
        • 10483
        Re: Oil Pan 69 427
        Joe may correct me, but not long ago you could buy the pan from GM. You would need to fill the part number stamped on the bottom, but the rest is very close
        Dick Whittington
        • Ned T.
          • December 29, 2008
          • 188
          Re: Oil Pan 69 427
          Im guessing the GM one would have the baffle in the bottom and the reinforced corners already installed. I have also seen them with the corner reinforcements shipped loose. It looks like the GM one from Dr. Rebuild is the one to go with.
          Ned
            • 43290
            Re: Oil Pan 69 427
            Dick-----
            I show the pan as still being available from GM. However, I'm sure they were Paragon's source, too, and if Paragon has discontinued them, that may mean that GM has, too.
            As you note, the GM pan is very similar to the original 1965-74 Corvette oil pans. The internal baffling is the 70-74 style (which is the same as 65-69 except it's about 1/4" lower). This difference is basically indiscernable with the pan mounted on the engine.
            The other difference is the pan lacks the corner reinforcements. No problem here, though, as the reinforcements are available in reproduction. While they were spot-welded on original pans, that was just a manufacturing convenience. The bolts will hold them on just fine and no one will ever know the difference.
