coil spring compressor arm stuck - NCRS Discussion Boards
+ More Options
Posts
  • Craig O.
    • July 31, 1983
    • 207
    Well things went along pretty good using an internal spring compressor. got the spring in, lined up my marks that i made on the spring and the outside of the spring pocket so the end of the spring would be in the proper spot near the upper stop. when its compressed there is ample space between coils, but when pressure is relaxed of course the coils become tight and the upper side of the coil progression is tighter anyway. connected up the spindel to the ball joint, torqued the castle nuts and started to remove the threaded rod.
    got the rod out and the lower finger clamp but the upper finger clamp is pinched in the coils up in the tower pocket, cant move it.
    any one have any Ideas? I sure dont want to start over.
  • Paul O.
    • August 31, 1990
    • 1716
    Re: coil spring compressor arm stuck
    Craig I think the problem you are having is that you should only be using the the lower fingers don't use both sets remove the one that slides. You need to have the threaded rod go through the upper shock hole with the nut above the hole and have the fingers up about 2 to 2 1/2 from the bottom coil of your spring. This will allow you to pull your spring into the upper mount for the spring. Hope that helps. Paul 18046
    • Chris F.
      • April 1, 2006
      • 23
      That's good information Paul I will bear that in mind when I pull my springs again. What a hassle last time.
