67 clutch fan dating - NCRS Discussion Boards
  • Mike E.
    • February 28, 1975
    • 5138
    I'm helping on a May-built 67, 300hp California car. The clutch fan (type 2) has the proper "CJ" stamped on it. It also has what appears to be B13H. Can anyone decipher that? I checked the archives, but found nothing apropos. Obviously B13 could be a date, and fits the car. (The fan blade has a "D" stamped in it.)
    Thanks in advance.
  • Larry M.
    • January 1, 1992
    • 2691
    Re: 67 clutch fan dating
    Mike:
    Info in my files indicates that the first letter is the month, the number is the day of the month, and the last letter is the year.......beginning with 1960 = A.
    B13H would then decode as February 13, 1967.
    Not sure about the fan blade.
    Larry
    • Mike M.
      Director Region V
      • August 31, 1994
      • 1463
      Hi Mike
      Good date as Larry mentioned.
      The stamp on the blade should be a "W".
      HaND
      • Mike E.
        • February 28, 1975
        • 5138
        Re: 67 clutch fan dating and fan blade dating
        Originally posted by Mike Murray (25129)
        Hi Mike
        HaND
        The W is there, on the center portion, not too far from the hub. The D is stamped only on one blade.
        Has anyone else seen a single letter stamped on the blade of one of these fans? I've had a bunch of 62's, and never seen that.
        • Mike M.
          Director Region V
          • August 31, 1994
          • 1463
          No Mike, I've not seen a "D" and cannot any reference to a "D" in the manuals, books or publications.
          HaND
          • Joel F.
            • April 30, 2004
            • 659
            Mike,
            Can you post a picture of what that date code looks like? I do not know if I have ever seen one.
            thanks
            Joel
            • Mike M.
              Director Region V
              • August 31, 1994
              • 1463
              Hi Joel,
              mine are still in the snow packed shed.
              I'll try to get in tommorrow, I need to take more shots anyway.
              Maybe someone can jump in sooner.
              HaND
                "The W is there, on the center portion, not too far from the hub. The D is stamped only on one blade.
                Has anyone else seen a single letter stamped on the blade of one of these fans? I've had a bunch of 62's, and never seen that."
                I agree Rev Mike...never seen a factory original fan with any emboss on the blades EXCEPT for 7-blade A/C fans. The 5-blade fan used in '67 is the SAME part number as you're used to seeing on your '62.
                The only difference between your SA fan and the '66-70 version of the same PN is the geometry of the rivets used to affix the blades to the center spider...
                Best, Jack Humphrey
                • Joel F.
                  • April 30, 2004
                  • 659
                  Hi Joel,
                  HaND
                  Thanks Mike!
                  The weather by me has probably been about the same as yours so I understand completely. No hurry, but I'd love to see a photo when the weather gets better.
                  Joel
                  • Mike E.
                    • February 28, 1975
                    • 5138
                    Joel--
                    I'll try to get a pic to you tonight.
                    Mike
                    • Mike E.
                      • February 28, 1975
                      • 5138
                      Joel,
                      Let's see if I can get this picture up for you.
                      Mike
                      • Joel F.
                        • April 30, 2004
                        • 659
                        Hi Mike,
                        Thanks so much for the picture and email. Any chance you can post a picture of the B13H on the clutch as well?
                        All the best,
                        Joel
                        • Mike M.
                          Director Region V
                          • August 31, 1994
                          • 1463
                          Joel,
                          I can't seem to be able to get to the barn.
                          Please find the link below showing a date stamp, faint, but should be what you are looking for.
                          HanD
                          https://www.forums.ncrs.org/showthre...+Date&uid=2429
