Just thought I would update the NCRS Forum members in regard to my struggle and success in fixing the vibration in my 63 Coupe after installing the tremic 5 speed.
We knew that we had a problem with the fact that the transmission angle was at 2.5* down and the rear pinion was 1.7* down. In an effort to get them more parallel we did the following.
1. We used 65 body mounts to get a little more room in the tunnel
2. We used early Nova motor mounts to lower the engine and allow more tunnel room to raise the trans.
3. We did use the hockey puck idea between the body and the transmission cross member to ensure that the body had no sag
4. We placed a one inch plate between the rear-end and the cross member to change the angle of the rear pinion.
5. We cut the "donut" at the pinion to allow us to raise it up.
The end result was the tranmission angle is now 2.1* down and the rear end pinion is at .5* up. Althought the angle are not equal and offsetting, this has eliminated the vibration and the harmonics. We are pleased that this issue has been resolved for my car.
I hope that this may help someone else that has been chasing a vibration.
Henry Atsma
Henry Atsma
