How much of a problem is it to change the battery cables on my 75.Looks pretty straight forward..But looks can be decieving..
Battery cables
Re: Battery cables
Negative? Easy.
Positive? I hope your engine and trans are out.
Or, I hope you don't have an auto trans or a big block. The cable runs above the transmission and is not whatsoever easy to replace (assuming your 75 is like a 71, 72 and 74).Vice-Chairman (West), Michigan Chapter NCRS
