Stuck one the side of the road!!! How do we get home??? - NCRS Discussion Boards
  • Tom L.
    • October 17, 2006
    • 1439
    Unfortunately my '72's resto was completed in mid october, just before the snow started falling, and my wife and I are itching to plan trips. One problem though, we realized that vette's are not easily towed. This realization came on the way home from picking the car up from the shop.
    Short story...Broken belt, a towing company that wouldn't touch the car, wire ties used as a belt to get it to a friends home (Safety for the car!!!) but far from my home.
    My question is; When out on the road, how is a suitible tow found???
  • Jeffrey S.
    • May 31, 1988
    • 1882
    Re: Stuck one the side of the road!!! How do we get home???
    If you are a AAA member, when you call tell them you need a flat bed and they will send one. If you're not a member you should be for that reason. Been there, done that more than once.
    Jeff
    • Tom L.
      • October 17, 2006
      • 1439
      We are members and that's who we called. They asked if it was low to the ground (DUH!!!) and if if might scrape front or rear. When I expressed doubts they said they would not touch it.
      • Tom H.
        • December 1, 1993
        • 3440
        As said before. Request a rollback, They go right on with no issues. Loaded a ton of em.
        Tom Hendricks
        Proud Member NCRS #23758
        NCM Founding Member # 1143
        • Jeffrey S.
          • May 31, 1988
          • 1882
          Lynn:
          I'm sorry that you had trouble getting the help you needed. The dispatcher just didn't have a clue. If you request a flat bed they will find a tow company that has one and send it. I have had to do this on several occasions- once in Ann Arbor, MI on my way home from Bloomington many years ago at 1 in the morning! Requested a flat bed and that's what picked us up.
          Jeff
          • Jim H.
            • April 1, 2002
            • 112
            Originally posted by Jeffrey Salz (13182)
            Lynn:
            Jeff
            If it was me I would tell my wife to get out and push...
            • Sandra H.
              • August 29, 2007
              • 262
              Would SO love to be standing around to hear her response. Good Luck, Sandy
              • Wayne K.
                • December 1, 1999
                • 1030
                " If it was me I would tell my wife to get out and push "
                And that's when the fight started.
                  And the funeral will be where?
                  • Mark P.
                    • May 13, 2008
                    • 934
                    Is a Roll-back when the car is loaded rear end first ?
                    When my C1 was loaded onto a AAA flat bed the front valance (fiberglass section under the front bumper) scraped on the bed.
                    • Kenneth B.
                      • April 10, 2008
                      • 39
                      IMHO Any tow operator worth his salt will know how to work around the clearance issue. I just had my 1990 Thunderbird SC flatbed towed a week ago - it has very low front & rear valances. No problem. The right driver will load it quickly and carefully and make it look easy.
                      • Jim H.
                        • April 1, 2002
                        • 112
                        its all good... She has a strong back and legs.
                        • Jim H.
                          • April 1, 2002
                          • 112
                          Just make sure whoever hauls it is not this guy! I know everyone here has seen this picture!
                            • 3416
                            Just about ANY Corvette will go on a rollback!!!
                            • Tom H.
                              • December 1, 1993
                              • 3440
                              Right on, Ken ! I can put a new ZR1 on a rollback with no problems. Those are as low as a car can get in the nose. A driver can always use planks and or blocks to overcome clearance issues.
                              Tom Hendricks
