C2 fasteners - NCRS Discussion Boards
C2 fasteners
  • Joseph U.
    • April 30, 2001
    • 241
    C2 fasteners
    Is there a guide anywhere to help with deciphering the AIM regarding fasteners. For example I am re-installing the power antenna on a 66 coup. Screw 9420152 is used to fasten the ground strap to the frame with a star washer and bolt 9418423 is used to fasten the bracket to the car at the rear tire well. I know that I can keep going to CC to buy these but seems expensive (especially if you add shipping etc - and the wait if you want to install something). All the judging guide says is recessed cadmium or zinc plated hex-head bolts. Size, thread, length not specified. It would seem that there must be a code for these fasteners - even if you don't have the correct head markings etc. I would doubt that I am the first to question this but I searched the posts and found nothing in this regard. Any help would be appreciated.
    Joe
  • Rich P.
    • January 11, 2009
    • 1361
    Re: C2 fasteners
    Joe,
    No easy answer here and no end all list of fasteners. I can tell you the description of the 2 bolts you are talking about to help you get it back together.
    The ground strap bolt is 1/4-20 thread (originals had a 3/8" head and a thread cutting notch) but any 1/4-20 thread bolt will work. (I think 1/2 long)
    2nd bolt is the antenna mount plate bolts, 1/4-28 thread 5/8" (or close) .
    Hope this helps you.
    Rich
    • Joseph U.
      • April 30, 2001
      • 241
      Re: C2 fasteners
      That is what I needed to Know. How did you know that? Is it written down somewhere or did you just keep good records?
      Joe
      • Rich P.
        • January 11, 2009
        • 1361
        Re: C2 fasteners
        Joe,
        neither I have had the privilege of restoring and working on nice original unmolested Corvettes since 83.
        Rich
        • Joseph U.
          • April 30, 2001
          • 241
          Re: C2 fasteners
          Lucky you.
          Locked up in your brain is a wealth of information for rookies like myself.
          You should write a book (like you don't have other things to do, I'm sure!)
          thanks for the help.
          Joe
          • John D.
            • June 30, 1991
            • 874
            Re: C2 fasteners
            Joe,
            This may help. They look like generic screws to me. Hope it helps.
            john
            • Joseph U.
              • April 30, 2001
              • 241
              Re: C2 fasteners
              John,
              That is GREAT - where did you get that from?
              I sure could use a copy of that resource.
              Joe
              • Mike M.
                Director Region V
                • August 31, 1994
                • 1463
                Re: C2 fasteners
                And a reminder Joseph,
                the star washer goes between the ground strap and the frame.
                Not under the bolt head.
                HaND
                • Joseph U.
                  • April 30, 2001
                  • 241
                  Re: C2 fasteners
                  Got it,
                  THanks
                  joe
                  HaND
                    • March 31, 1990
                    Re: C2 fasteners
                    Sometimes it's better NOT to ask where someone obtained GM drawings! The source is typically a GM employee with access to the drawing system and such are not to be released to the general public... Source disclosure often winds up curtailing future access!
                    • Joseph U.
                      • April 30, 2001
                      • 241
                      Re: C2 fasteners
                      Thanks for the insight,
                      Joe
                        • November 30, 1997
                        Re: C2 fasteners
                        Joe -
                        Richard Fortier has those bolts, his part #PA-3714; see his ad on page 78 of the January-February "Driveline".
                        • Joseph U.
                          • April 30, 2001
                          • 241
                          Re: C2 fasteners
                          Thanks john,
                          But I went down to Home Depot and bought 2 bolts today - according to the spec sheet they are just 1/4 inch dia 3/4 inch long with 28 threads/inch zinc or cad plated. Judging guide doesn't say anything about head marks and it looks like they would be hard if not impossible to see anyway. 13 cents - hard to beat -
                          Am I making a mistake here?
                          Joe
                          Joe -
                            • November 30, 1997
                            Re: C2 fasteners
                            Joe
                            Probably not - it's a very minor deduction if noticed.
                            • Joseph U.
                              • April 30, 2001
                              • 241
                              Re: C2 fasteners
                              Thanks John,
                              If I get that close that those two bolts make the difference then I will know that I did a good job with the restoration and live with it (second flight) with pride.
                              Joe
