Does anyone have any tricks to remove some haze from stainless trim?
I repaired a ding in my T-top stainless and proceeded to polish it with my Caswell buffing kit. The repaired area was sanded with 400 wet, 600 wet and then a final with 1200 wet. Then buffed with the stiff sewn wheel(with fibers) and black compound, then switched to the semi stiff sewn wheel(no fibers) and green compound and last, the loose cotton wheel with green compound. This is all as per the Caswell instructions for buffing stainless steel.
The repaired area came out really nice but the rest of the trim is hazy and you can see where I sanded and didn't. The sanded area is nice and deep like the chrome corner pieces but the rest still has a haze on it. I sanded on another area and then buffed and it came out nice and deep with no hazing, it's almost like a very thin layed of the stainless is oxidized and has to be removed first???
So when buffing stainless are you supposed to pre-sand the part before you start buffing or am I just doing something wrong?
