Just the tray, nothing but the tray.... - NCRS Discussion Boards
  • Irby G.
    • November 1, 2001
    • 267
    Does anyone know where to get just the battery tray? I want to use my original 'legs' and spot weld them on to a new tray. I saw just the tray offered at one time but I can't remember which parts provider had it.
  • Stuart F.
    • August 31, 1996
    • 4676
    Re: Just the tray, nothing but the tray....
    Why would you want to do that? I replaced mine many years ago and expect I will have to do it again in the not too distant future (I use wet batteries). I had to do a little twisting and turning, but I got it bolted up ok. Can any one tell an original from a repro and how??
    Stu Fox
    • Irby G.
      • November 1, 2001
      • 267
      I have a repro and compared it to the legs off of my original and they're close but do have a few differences. Does anyone know if the repros judge out okay?
      If they do, I'll just bolt the repro on and be done with it.
      • William C.
        • May 31, 1975
        • 6037
        Depends on the Judge, should look for the proper gusset configuration, many do.
        Bill Clupper #618
        • Mike M.
          • May 31, 1974
          • 8408
          clup is right on. i simply buy a repo tray and remove its legs and reweled the original GUSSETED legs on the repo tray.mike
          • Irby G.
            • November 1, 2001
            • 267
            Mike,
            What is the best way to remove the legs without mussing the tray up? They put about 8 spot welds on each leg.
              Carefully drill out the spot welds...
              • Mike M.
                • May 31, 1974
                • 8408
                Originally posted by Irby Gauthier (36953)
                Mike,
                As jack stated, i drill the various spot welds of the repo 90% thru the legs (not going tru the tray bottom)then simly bend back and forth till the leg and tray seperates. on the original, drill clear thru each spot weld to remove the donor legs. then mig weld old legs to new bottom at all the points you've drilled thru. grind down and repaint. . sounds like an orthopedic proceedure, don't it? mike
                • Ronald L.
                  • October 18, 2009
                  • 3248
                  Does anyone have a picture of an original RH tray leg area?
                  427 if that matters...
                  I have heard the re-pop is not the same and yet not sure what the original looks like.
                  • Ronald L.
                    • October 18, 2009
                    • 3248
                    Correct battery tray for 1966
                    • Mike M.
                      • May 31, 1974
                      • 8408
                      original legs have gussets stamped in them, whereas the older repos lack the gussets. sorry but no pictures. mike
                      • Alan D.
                        • January 1, 2005
                        • 2053
                        Ron, this is from a 64 SB. Not sure if that's the area under discussion. Check with Mike for comments. Not the best photo, sorry.
                        • Doug L.
                          • March 14, 2010
                          • 442
                          As for drilling out the spot welds, you can buy a bit made especially for that purpose. You start by drilling a small hole (approx 1/8") in the center of the spot weld with a standard bit. The special spot-weld bit has a center pin that will drop into the hole created by the ~1/8" bit. The rest of the special bit is almost like a small hole saw. If you use it on the side of the piece that will not be reused, you can drill through that disposable part and stop when you get through that first layer. The part to be reused then only has the 1/8" hole in it. One of the tool trucks that frequent auto repair shops will carry them. Maybe auto parts stores too.
                          • Michael M.
                            • February 1, 1993
                            • 606
                            Irby the tool Doug is talking about is called a Blair cutting bit. Doug described the way the tool works to the tee. It's not the only way to drill out spot welds but in my opinion it's the best and neatest way.
                            • Ronald L.
                              • October 18, 2009
                              • 3248
                              Here is one that I think falls into the early reproduction category, pics 1 & 2.
                              Comments anyone, Mike?
                              Then one of the big box vendors has this called out as a correct 66 427 RH and it is no where near anything.
                              So yes I am looking to verify 66 427 RH mount.
                              thanks,
