67 door panel screw location - NCRS Discussion Boards
  • Randy R.
    • March 1, 1983
    • 477
    I am trial fitting a set of repro door panels on my 67 convertible. Are there measurements for the location of the trim screw on the rear edge of the door panel or should I just approximate the location based on to hole in the original door panel?
    I read the recent thread on the type of screws to use. I am left with the impression that a number of different types of screws are likely to have been used. Is this corrrect?
    Thank you,
    Randy
  • Kurt K.
    • June 30, 2004
    • 194
    Re: 67 door panel screw location
    I would use the hole in the door as a guide as to where the screw is to go thru the panel. The screw is a specific type. My car has original door panels and only one has this screw. I always wondered why?? Kurt
    • Gerard F.
      • June 30, 2004
      • 3806
      Randy,
      I think that different types of screws were used. I had a different screw side to side on my 67 convertible.
      If you look in the 67 AIM, you won't find a callout on this screw, but some elaborate clip assembly that was supposed to be added (2-8-67 change). Maybe I'm wrong.
      I think the factory guys improvised and used one of the old or new kick panel screws, or rear quarter panel screws, instead.
      There was a discussion with pictures on this subject not too long ago.
      Would just love to have someone show me where this screw is called out in the 67 AIM.
      Jerry Fuccillo
      • Lawrence S.
        • April 1, 1993
        • 803
        I would use the hole in the door as a guide.
        I bought my replacement screws from Long Island and had no problem when my car was judged.
        Good Luck
