63 Fan Shroud - NCRS Discussion Boards
63 Fan Shroud
  • Daniel K.
    • April 1, 2002
    • 190
    63 Fan Shroud
    Good morning all,
    Can you please help to ID if a steel 63 fan shroud is OEM? What would we look for to determine if the shroud is correct. Many thanks! Dan K.
    Re: 63 Fan Shroud
    That's exactly what the '63-64 Judging Guide tells judges to look for...
    • Jim L.
      • September 30, 1979
      • 1816
      Re: 63 Fan Shroud
      If it is a '63-specific shroud you need, keep in mind there is a 1st design and a 2nd design shroud. They differ, at a minimum, in that the 1st design does NOT have a clearance notch on the passenger side mounting flange for Powerglide oil-cooler hoses. 2nd design shrouds have this notch.
      Jim
