67 pedal box question - NCRS Discussion Boards
  • Chris E.
    • November 3, 2006
    • 1331
    I'm working on refurbishing the pedal box on my 67. When I cleaned it up, I noticed that there was a break between the black paint and what looks like the original surface (unpainted). Is this the way they came from St. Louis? Just curious.
    Chris Enstrom
    2011 Z06, red/red
  • Stephen L.
    • May 31, 1984
    • 3159
    Re: 67 pedal box question
    Yes. Mine are the same way. Appears pedal was dipped in paint and the unpainted area was that way because of the shaft rotation
    • Wayne M.
      • March 1, 1980
      • 6414
      Agree with Steve -- here's clutch pedal of late '65, showing paint dip line, and close-up is of cracked original alongside an NOS '63-6 type. The latter was entirely painted, I suppose so that it wouldn't rust on the shaft surface while in storage.
      Note tack weld on service replacement, versus the crimp/punch line on production unit.
      • Stuart F.
        • August 31, 1996
        • 4676
        So Wayne, have you learned to stay away from those B & B white spring pressure plates yet?
        Stu Fox
