ZL1 Dual disc Clutch - NCRS Discussion Boards
  • Peter K.
    • June 30, 2006
    • 3
    I am trying to set up a ZL1 (MA6 Heavy duty) dual disc clutch on a 1968 427 car. The first disc next to the fly wheel disengages fine but the second disc by the transmission hangs. I'm wondering if there is a set up method that anyone is aware of to properly align the clutch. Are shims required? Any advice would be much appreciated - thanks
  • Warren F.
    • December 1, 1987
    • 1516
    Re: ZL1 Dual disc Clutch
    Peter,
    The MA6 dual plate clutch assembly uses 4 unique parts that are not the same as the single 11 inch style clutch set-up. Do you have the correct flywheel, pressure plate, discs & intermediary plate?
      • 43221
      Peter----
      I don't know how to deal with your problem. However, I don't think that any shims were originally used, at least none that were installed after the assembly was manufactured.
      Also, the dual disc clutch was NEVER used for a ZL-1 or L-88. It was used ONLY for 1969 with L-71 and MA-6 and all 1971 LS-6 with manual transmission. That's it.
      • Peter K.
        • June 30, 2006
        • 3
        Warren,
        I have all the correct parts including the flywheel, pressure plate (intermediate plate) and friction discs.
        peter
        • Peter K.
          • June 30, 2006
          • 3
          Joe,
          I realize that it was not a factory option for my car. I am restoring a Motion car that had an L88 short block and ZL1 clutch among other preformance mods installed in early 1970. The pressure plate is 10 spline so it is the correct one for the date of the original modifications. I have original GM invoice for the short block, as well as documentation of the Motion parts.
          Peter
          • Steven B.
            • June 30, 1982
            • 3990
            Joe,
            Peter
            Great car!!! Joel Rosen turned out some screamers.
            "Got Pics?"
