'64 Interior Saddle Tan Paint Color code? - NCRS Discussion Boards
  • David D.
    • January 1, 2005
    • 416
    I am wanting to paint my '64 Saddle Tan interior parts (i.e. Center Console)
    Anyone know the paint number, and or manufacturer(s) that I could use and still be close to original color?
    David
  • Dan H.
    • July 31, 1977
    • 1372
    Re: '64 Interior Saddle Tan Paint Color code?
    Hi David, on my saddle/saddle 64 I used the codes in Noland's book for Dupont paint. Not sure if the tints are still available now, best thing to do is take any original part to a paint shop and have them computor match it. The radio side panels might be a good candidate. Good luck!
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • M W.
      • July 31, 2001
      • 835
      David, I bought the saddle tan spray from LIC and it matched fine. No comments made during Flight Judging. Easy way to do it.
      Cheers,
      Craig Willetts
      • David D.
        • January 1, 2005
        • 416
        OK thanks....I'll get some from LIC. I was just looking to see if a Krylon (for example) was available where I could pick some up locally.
        David
        • M W.
          • July 31, 2001
          • 835
          Hurry up and get that beauty running so we can have a reunion of sorts. Lots of 64 owners around here.
          Cheers,
          Craig
          • Harry S.
            • July 31, 2002
            • 5344
            I just looked at the spray cans I used to fix up my saddle 63 interior. They are from paragon, its' a saddle dye. I did get a can of saddle lacquer from Tower Paints (google them). They mixed the paint and put it in a rattle spray can for the interior metal trim of my hardtop.
            • Joe M.
              • February 1, 2005
              • 590
              https://www.forums.ncrs.org/showthre...addle&uid=1254
              • Curt C.
                • May 31, 2000
                • 49
                David, I used the LIC product (spray dye on sandless primer) on my 64 as well and it worked fine. My radio panels were rough. The Tower paint rattle can product is a good choice also. They mixed up some Trophy Blue lacquer for my 66 that was excellent.
                • Alan D.
                  • January 1, 2005
                  • 2053
                  Question? Know the 67 tan color is different for sections of the interior. Was the tan a consistent shade throughout the interior for the 64 MY?
                  • Wayne M.
                    • March 1, 1980
                    • 6414
                    Not according to Chev Service News, Sept 1963 (for the new '64 models). for 1964 Corvettes, there are two interior refinish paint codes, both called Medium Saddle. The 60 gloss is (using Dupont codes for example) 9015-L; the 3 gloss is 4461-L). The lists of what-goes-where for the different interior parts been posted before.
                    • David D.
                      • January 1, 2005
                      • 416
                      Wayne, I'm old, tired and am having little to no luck with searches of this calibre. Do you simply know which one would be correct for early '64 (Nov of '63) center console, or have that link to reference you mention above.
                      Thanks in Advance,
                      David
                      • Wayne M.
                        • March 1, 1980
                        • 6414
                        Originally posted by David Duell (43184)
                        . ....Do you simply know which one would be correct for early '64 (Nov of '63) center console, or have that link to reference you mention above....David
                        Here's the link to a previous thread.
                        https://www.forums.ncrs.org/showthre...94291&uid=8866
                        To get the whole story for the low gloss and high gloss lists you have to read post # 2 and 6 of this thread. So far, the "what-goes-where" source is from one paint manufacturer for the 1965 year, so I can't guarantee it applies to 1964, although the two Dupont codes I specified earlier are for 1964 Corvettes.
                        Nowhere does the list specify precisely the center console (ie. the shifter plate) although I think it should be the low gloss called for the radio speaker panel. Can get you the other two interior '64 paint suppliers; one can be used for low gloss and the other supplier for high gloss. Only Dupont had codes that covered both.
                          Adding on...the autocolorlibrary.com website gives 'page two' information for certain year cars. This is available for '63, 64, and 65 (among others). This recites what blend codes were used + where on interior parts.
                          In '63-64, the specs for Corvette are broken into three categories: flat, low and full gloss. BUT, for '65 the spec sheet is more detailed and calls out 'low' gloss to be 3-degrees! This is the category the center console falls in.
                          Knowing what gloss factor to target, a professional painter can hit the job on target!
                          • David D.
                            • January 1, 2005
                            • 416
                            Thanks Wayne and Jack...
                            David
