Wire Harness Push-In Clips - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Can anyone possibly tell me where I could find two white push in clips which are used to attached the main headlight wire harness to the body in the valance area? They fit in where the two headlight motors are. I pulled my original ones out to clean the harness and realized I pulled to hard and the clips will not stay in now.
    Any help is appreciated.
    Craig W.
  • Alan D.
    • January 1, 2005
    • 2054
    Re: Wire Harness Push-In Clips
    Craig - are you talking about the round white plastic on the back of the light motor housing, the ones that protect the two male connectors??
    Or the end with the female connectors which is part of the harness?
    For the second (harness, female) - try crimping the female connectors a little on each edge (two edges/connector)
    As for the motor end, do not believe the white plastic is removable unless the back metal cover is removed which is welded.
    • M W.
      • July 31, 2001
      • 835
      Alan, I am referencing this particular one. The picture quality isn't the best but it's the one that is taped into the front harness itself. One of the two male ends are broken off.
      Craig
      • Grant M.
        • August 31, 1995
        • 448
        I think they're identical or at least similar to the one that holds the alternator harness to the alternator case. I bought some from Dr. Rebuild I believe, or possibly one of the other small parts vendors at Carlisle.
