64 spindles - NCRS Discussion Boards
64 spindles
  • Richard B.
    • May 31, 1984
    • 37
    64 spindles
    Im tying to figure out witch style nuts are correct for the bolts that go through the front brake dust shields to the spindles thank you
  • Timothy B.
    • April 30, 1983
    • 5194
    Re: 64 spindles
    Richard, They are self locking grade eight nut. There was a discussion a while back about these check the archives.
      • 43246
      Re: 64 spindles
      Richard-----
      They were a conical head, cadmium (NOT zinc) plated, stover-style, distorted thread, 7/16-20 lock-nut of GM 301M material grade (SAE grade 8) and of GM #9422300. They were discontinued from SERVICE several years ago.
      Finding a locknut of the correct configuration/finish appearance is quite easy. Finding one of the correct configuration/finish AND of the correct material grade is NOT so easy. What makes it worse is that these nuts have critical safety implications and a lower grade nut must NOT be substituted.
      Do not use hardware store lock nuts. They will be of ungraded material and WAY too inferior to use for this application.
