1972 LT-1 W/Air Vacuum Hose Pics - NCRS Discussion Boards
  • Martin Z.
    Infrequent User
    • January 1, 1998
    • 26
    Does anyone have a photo or illustration showing the vacuum hose route from the distributor to the carb etc. on a 1972 LT-1 with air?
    • 15599
    Re: 1972 LT-1 W/Air Vacuum Hose Pics
    If by AIR you mean C60 air conditioning -- there is no difference in the vacuum routing from the carburetor, through the TCS solenoid to the distributor vacuum advance whether the car has C60, air conditioning, or not. Since all 1972 (and other year) LT1 had AIR (Air Injection Reactor), that vacuum routing will be the same regardless of the C60, as well.
    The AIM has a drawing of this vacuum circuit, and I believe there is a photograph (or two) in the VetteVues Fact Book 1968-1972, by MF Dobbins. Both of those publications are available from the NCRS Store. Just a couple of clicks away via the button of the same name at the top of the page.
    • Roy V.
      • April 8, 2008
      • 301
      Martin, if you have a catalog from Doc Rebuild there is a nice illustration on page 85, maybe you can even view it on his online catalog.
      Good luck
      Roy
      1972 LT-1 Elkhart Green Coupe
