C3 Air dam - NCRS Discussion Boards
C3 Air dam
  • Jeff W.
    • November 1, 2005
    • 272
    C3 Air dam
    Any idea on what type of glue to use on my new air dam attached to the radiator frame?
    Thanks for the help.
  • Paul O.
    • August 31, 1990
    • 1716
    Re: C3 Air dam
    Jeff are you talking about the seal between the hood and rad support or the seal at the bottom of the rad support. Paul 18046
    • Tom H.
      • December 1, 1993
      • 3440
      Re: C3 Air dam
      Is it the foam part ? 3M weatherstrip adhesive ?
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
        • 43247
        Re: C3 Air dam
        Jeff-----
        The equivalent of 3M Super Weatherstrip Adhesive is what was originally used. So, if you use that product now, not only will it work just as good as ever, you'll be "correct", too.
        • Jeff W.
          • November 1, 2005
          • 272
          Re: C3 Air dam
          Thanks all
