door ajar switch on 72 - NCRS Discussion Boards
  • Gene M.
    • April 1, 1985
    • 4233
    Is p/n 3929804 correct for rear door jam ajar switch?
    It has three wires with small pins that plug into switch, where can I find the pins? Can't find them listed.
    Are the available switches originals or repro?
  • Ken C.
    • August 31, 2006
    • 120
    Re: door ajar switch on 72
    the switches can be found at GM dealers. They with not have the SX as originals. The pins can be found at dr. rebuild, paragon, etc.
    • Paul O.
      • August 31, 1990
      • 1716
      Gene check Lectric Limited http://www.lectriclimited.com/ go to the repair components then online catalog they should be listed there your pins p/n should be 06288128-6 I would still just call them to get the right parts. The switches now are repros but you still can find originals with and without the SX on the head of the pin on ebay or at part swap meets. Paul 18046
