Anti-seize - NCRS Discussion Boards
Anti-seize
  • Stephen R.
    • May 20, 2008
    • 302
    Anti-seize
    Ok, 35 years when I rebuilt my 283, I used anti-seize on pretty much everything thinking one day I may want to take some things apart. Today's the day. I'm going to install the ignition shielding brackets, so I have to remove two intake bolts and the exhaust manifold bolts. How long does that stuff last? Especially on the exhaust manifold? What's the chance of snapping a bolt? My exhaust has bolts and not studs.
  • Rich G.
    • January 9, 2009
    • 51
    Re: Anti-seize
    Shouldn't have a problem,those bolts are not a problem usually. It's the exhaust pipe to the manifold that gives you the problem. If it's tight, work it back and forth slowly so it doesn't snap.
    • Stephen R.
      • May 20, 2008
      • 302
      Re: Anti-seize
      Thanks Rich, appreciate the advice.
