64 Turn Signal Switch - NCRS Discussion Boards
  • Steve G.
    • March 1, 1993
    • 43
    I need to replace my turn signal switch can anyone tell me the best way to remove and install the switch ? Thanks
    Re: 64 Turn Signal Switch
    Disconnect the 'harmonica' connector from the lower side of the steering column. Turn it sideways (to minimize width relative to the harness) and tape it to the harness so it can't move and/or catch.
    Now, attach a pull-string or wire to the bottom end of the harness. Remove the switch from the upper column and SLOWLY + CAREFULLY wiggle and pull the harness up and out of the column dragging the pull-string with it.
    Reverse the proceedure when installing your replacement switch/harness assy and use the pull-string to draw the harness down/through the interior of the column.
