Headlamp Vaccum Hose Tape 72 - NCRS Discussion Boards
    • 6960
    What Type Of Tape Wraps The Headlamp Vaccum Hoses- And Is It Possiable To Still Get, Maybe Something Like The Correct Tape- It Appears To Be Like A Cloth Tape That Is There Now. Thanks For The Response Ed.
  • Dennis D.
    • March 1, 2000
    • 1071
    Re: Headlamp Vaccum Hose Tape 72
    This what you mean? Has gotten yellowed over the years. Seems to be a sort of white string/clear tape. Check the archives
    • Dick W.
      • 10483
      3M Filament Packaging Tape
      Dick Whittington
        • 11698
        1972 did not use the clear filament style of tape. That ended in 1970.
        I think that the only types of wrapping used are the wide "non-sticky" tape that is on all the wiring, and the black cloth tape used to bundle the hoses together. There may be some "black electrical tape" also used in bundling but I'd have to go look.
        This picture shows the black cloth tape as used on some of the vacuum lines to help bundle. It is here on the PCV line. I have used black cloth electrical tape, as it's as close as I could find.
          Yes, it's a form of cloth tape. I talked a reproduction wiring harness vendor into spotting me a 3-foot section of what he uses (have to cut the width down to match what was used in this application).
          Since, I've found the same tape was used on other cars/trucks of the era to hold wiring harness assy's together when they were routed along the same path. The most common place to find 'pristine' pieces of the factory original cloth tape material is in the trunk areas of similar era passenger cars (e.g. Cadillac) and you can 'harvest' some at your local scrap yard...
            • 11698
            I'd knew you'd probably chime in with that.
            However, here in Michigan cars from the 60's and 70s rusted out and were turned into scrap by about... 1980. Thus, I use what I can easily find since there is no way to "easily find" a scrap car of similar vintage to my Corvettes.
            Patrick
            • Bryan M.
              • April 1, 1999
              • 386
              The cloth tape reminds of the friction tape that my father used as a lineman.
              • Brad M.
                • July 31, 2005
                • 262
                is the cloth tape the same as used for TI wiring harness? If so, reproduction versions are available.
                • Christopher K.
                  • September 10, 2007
                  • 311
                  Ed,
                  I searched a lot of places and then found the perfect match at Home Depot. 3M Friction Tape, in the electrical section. Even has the white strings through it.
                  Chris
                  Chris
                  '72 Lt-1 a/c Pewter Silver coupe Mason Dixon Chapter Top Flight 2016
                  '73 L82 4 spd Dark Metallic Blue coupe Chapter Top Flight 2023
