1971 LT1 Emissions hoses - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    1. Can someone describe the hose system from the vapor tank to the PCV valve and, the holley carb/. Plase include writing on hoses and color of clamps.
    2. Descrive the clamp holding the rubber line from the PCV to the distributor. Pictures would help. Thanks
    • 15645
    Re: 1971 LT1 Emissions hoses
    Paul,
    Are you a teacher, by chance?
    • Paul C.
      • November 12, 2007
      • 511
      Let me restate my question
      From the 1971-72 judging guide and looking at my car this would seem to be the description:
      Two hoses run from the carb.
      1. the smaller one runs from the carb to the ECS cannister and has a white line on it.
      2, The second larger hose starts at the carb with EVAP 1444 HJ until it connects to a black plastic T. One end of the plastic T has larger diameter than the downside end. The downside black tube has EVAP on it and continues to the cannister.
      3. The other end of the black plastic T connects to the PCV (#CV746C) by way of a piece of black tube with the numbers: a big 8, hen a litlle 8, and then 1030. The short black tube is connected with 2 green clamps to the PCV.
      Is everything OK for NCRS judging as I described? Did I miss anything?
        • 15645
        • Paul C.
          • November 12, 2007
          • 511
          Your right the AIM shows a clampat the carb/ EVAP 1444 HJ tube and the other at the plastic T/rubber hose going to the PCV.
          Paul
