I have acquired a TI Distributor and new in the box GM coil for which I'm told is a service replacement. I would like to get some input as to these parts as there are some peculiarities.
The coil is # 12337166 it is marked Made in Mexico and has a low gloss finish. It appears to be a plastic material rather than the bakelite and metal like my original.
The distributor has no collar band but does have # 204146 stamped into the shoulder of the housing where it would meet the block. There is a "30" in the casting of the body adjacent to the tach drive housing. The tach drive insert is secured with a set screw, and there is no vacuum advance provision (it is not machined to accept one). The harness leads from the body are Red and Black and appears to be a silcone coated wire with standard connector as on my # 1111259 distributor.
Does anyone know what application it was intended for ? I will guess it was a GM Delco Remy service replacement part but due to the lack of vacuum advance must be for a race application or perhaps marine ?
Any information would be appreciated
Howie
Howie
