I made up a tool to install the Carpet Plugs/ Retainers in C3. I cut a screwdriver down top a little bit longer then the carpet plug the epoxied a fender washer to the handle where there it meets the shaft. Put a little bit of soapy water on the plug and push it in the hole. Also to remove there is a tool that can remove them without damaging.
