I believe that the trunk liner screws should be clutch head screws with a rounded type washer. I can find no reference to confirm it either in Noland Adams book or in the judging manual. Am I correct in the type of screws and washer and where can I find the definitive answer.
55 trunk liner screws
Re: 55 trunk liner screws
Don, trunk cardboard - division panel should have #10 clutch head screws into the metal on the sides and #10 phillips into the fiberglass. Both have a countersunk finish washers same type as the interior door panels have. Gary....
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
The four side screws are clutch head with round washers , the two for the jack handle are also, the bottom are Phillips with round washers,the two holding the jack bar are Phillips.I believe that the trunk liner screws should be clutch head screws with a rounded type washer. I can find no reference to confirm it either in Noland Adams book or in the judging manual. Am I correct in the type of screws and washer and where can I find the definitive answer.
None use the countersunk washers like the door panels .
- Top
