67 door panel - NCRS Discussion Boards
67 door panel
  • Dale S.
    • November 12, 2007
    • 1224
    67 door panel
    I pulled the 67 coupe passenger side door panel today. It had "M-B DEC 6 66" on the inside. It is a March 30th built car. Does that seem like a long lead time or did they not build many red interior coupes. Anyone else have panel dates like that? Dale
  • Rick S.
    • January 1, 2003
    • 1203
    Re: 67 door panel
    Dale,
    I had the job number inside each door, nothing like you describe.
    Rick
    • Kirk M.
      • June 30, 2006
      • 1036
      Re: 67 door panel
      Dale,
      Did you mean on the back of the actual door trim panel, or on the door itself? The back of the black "kickpanel" just behind the pass seat that runs up and covers the convertible top attachment region, anyway mine was marked in white paint "AUG 7 1966". So, if you mean the actual door trim panel, yours is later than my trim piece. My car was built April 18, 1967.
      Kirk
      • Dale S.
        • November 12, 2007
        • 1224
        Re: 67 door panel
        It was stamped on the brown fiberboard that the trim of the door panel is mounted on. It is between the door and the door panel. It was stamped in black ink. It was not the job number. Dale
          Director Region V
          • August 31, 1994
          • 1463
          Re: 67 door panel
          Dale, your door panel is good to go.
          HaND
