1966 coupe B.B. & A.C. - NCRS Discussion Boards
+ More Options
Posts
  • Robert P.
    Infrequent User
    • January 27, 2009
    • 2
    Iam just getting done restoring this car. Iam at the fan shroud seal & radiator seals. I need to know what seal to put on lower shroud ? The seal that i have from Dr Vette is rubber with a slot on one side does it just push on & or glued on the fan side of the shroud lower end. The assemblay manual does not show this. As far as radiator seals one on ea side of rad glued or just lay on ? Any help would be nice thanks Bob
    Re: 1966 coupe B.B. & A.C.
    Bob -
    The two vertical side seals are glued to the back side of the radiator support, as is the long horizontal seal just below the bottom of the radiator opening; use 3M weatherstrip adhesive (unless your sponge seals have adhesive and a plastic liner already on them).
    The rubber flap-type seal staples to the rear edge of the bottom of the fan ring that attaches with bolts to the bottom half of the fan shroud; this is shown in the Assembly Manual in Section C60, sheet B2.5, in the lower right illustration (the lower two illustrations on this sheet are only for the big-block application).
