65 Fuel Injection Transistor Ign Cap - NCRS Discussion Boards
  • James G.
    • May 31, 1976
    • 1556
    OK guys, got a question asked today.
    What is a correct 65 fuel injection with transistor ignition distributor cap look like?
    1.- Brown, shorter than a standard ignition cap, has copper connectors.
    OR
    2.- Black, shorter than the standard cap and actually looks the same as a fuel injection 63-65 cap, has copper or alumnium connectors.
    I believe #2 is correct with alumnium connectors. #1 was used on L-88 engines only.
    • 43213
    Re: 65 Fuel Injection Transistor Ign Cap
    OR
    Jim-----
    You are correct; #2 is how it was. The cap was a GM #1943047, aka Delco #D-310. It was BLACK with short towers and aluminum terminals. There may have been some D-310 caps manufactured that used the brown alkyd plastic and copper terminals but, if there ever were any, I think these were a later SERVICE piece.
    L-88 did not use a short tower cap, at all.
    • James G.
      • May 31, 1976
      • 1556
      Thanks Joe. I told the inquirer to read the web tonight when he gets home.
      Hope all is well with you Joe.
