BB valve spring shims - NCRS Discussion Boards
  • Joe R.
    • May 31, 2006
    • 1822
    I'm working on my shopping list for the valve train on my L-72 (427 / 425) that I am rebuilding. Can I reuse the valve spring shims or should I buy a new set? If I need new ones, what is the GM part number?
    Joe
    • 43295
    Re: BB valve spring shims
    Joe
    Joe-----
    You may be able to reuse the shims but I think that if I was replacing the springs, I'd replace the shims, too. They are GM #3875916 and they're still available for about a buck and a half each, GM list. These shims are 0.70" ID, 1.48" OD and .016" thick.
    • Clem Z.
      • January 1, 2006
      • 9427
      no matter what shims you use make sure the are hardened by hitting them with a file
      • Joe R.
        • May 31, 2006
        • 1822
        Clem,
        Can you please elaborate on what you mean by hitting them with a file? What type of file and what result am I looking for?
        Joe
        • Clem Z.
          • January 1, 2006
          • 9427
          Clem,
          Joe
          take a machinist file and push it across the edge of the shim and if the file cuts into the shim it is NOT hardened and will wear from the spring moving on the shim putting metal particles into the engine. if you need more than one shim to get to the 1.880 distance use a hardened shim directly under the spring but you can use non hardened ones under the hardened shim to get the correct distance.
