Thanks to all of those that have responded so far.
Yesterday I cleaned out all of the old "dum dum" or putty from inside the channel between the windshield in the header, mostly along the passenger's side where the rust is present. Thankfully there was no rust in the corner, and all looks well.
My plan for the rust and metal is to
- remove as much rust as possible with a wire wheel on a drill or Dremel.
- prep with "Rust Converter" material.
- paint with Eastwood's Rust Encapsulator
This should prevent any further growth of the rust. I am also going to try and spray "rust converter" and Rust Encapsulator inside the windshield frame upper using holes already factory supplied in the header.
The first question I have is this: I could replace all of the "dum dum" with strip caulk (same stuff) but I suspect that if I could use some type of sealant (silicone sealant?) it may work better at keeping out water. I'm thinking of the location/trough shown by the arrow in the picture below, not the large glob of sealant next to the chrome corner.
Next, I found a bit of surface rust where the T-bar meets the windshield header. Where the two are welded together it appears that the factory used wide masking tape to "seal" the back of the hole and then applied a hardening material (bond?) to cover it up. See below. Due to the rust I removed all of this material. My question is, what should I use to replace it? Bondo? JB Weld? Any thoughts?
Thanks for any assistance you can give.
Patrick
Patrick
