1964 Rear Frame Access Panel & Screw Finish? - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    Hi all again,
    Trying to locate in the judging guide information on the rear frame access panel and screw finish with no luck. Do anyone know the correct finish texture and where it's located in the 63-64 Judging Guide?
    Thanks as always,
    Craig W.
  • Jim W.
    • April 1, 2006
    • 228
    Re: 1964 Rear Frame Access Panel & Screw Finish?
    Craig,
    In the TJG 3rd ed. under wheelwells it says "after undercoating, these areas are blackened out with semi-gloss black paint". The 5th ed. explains further that the undercoating stops short of covering this mounting bolt access panel . Mine appears the same as described. So I guess the answer is they are painted black.
    • Jim W.
      • April 1, 2006
      • 228
      Picture of E64. screw headmarks are SEMS
      • Dan H.
        • July 31, 1977
        • 1372
        Hi, the panel was put on after body drop due to installing the body bolt there. Bolts should be unpainted, just the panel was painted. Bolts might be zinc, like the rocker panel bolts etc. Look in Noland's book, find bodies being dropping onto frame, no panel in place. A good one is in the 63 section. Happy hunting!
        Dan
        1964 Red FI Coupe, DUNTOV '09
