Shielding identification needed - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 948
    Can anyone tell me what this shielding is for ? I looked at the C2 and C3 shielding I could find on-line and I can't identify it. It is similar to 63-67 shielding.
  • Steven G.
    • November 17, 2008
    • 348
    Re: Shielding identification needed
    The shields as pictured, the left is the right side and the right is the left side. They are not for c-3 small block.
    • Alan D.
      • January 1, 2005
      • 2052
      Well can not tell from picture since even when downloading it's just tooo small to see any details. Here are some 64 shields to compare to which are in jpg which you can download and blow up to compare to yours.
      Hope these help.
      • Wayne M.
        • March 1, 1980
        • 6414
        Mark -- look at your forward attaching points (to the motor mounts). They're for the large (safety) style motor mounts. These began early in the C3 era, AFAIK.
        Here's a '66-7 set of boomerangs, very similar to what Alan posted. Again notice the forward attach point; different configuration that fits the smaller motor mount. There may be slight differences on the rear attach brackets geometry and indentations on your set, to clear something or other.
        I've included these pics to show logo stamping details on the brackets. I'm sure the 'B' on the RH forward attachment is the same as on the LH shield, but the identical reinforcement is just flipped, hence hidden. See the "AS" stamped on the rear brackets. Also, just noticed that my rivets are larger than Alan's.
        • Brad M.
          • July 31, 2005
          • 262
          i was thinking those might be consistent with the style used in 71-74, but not positive
            • 43263
            Mark-----
            These are 1970+ shields. There were several different part numbers used over the 1970+ years, but, for the most part, the actual shields varied only slightly. However, by the looks of these I'd say they are likely GM #3987342 and 3987341.
            • Steven G.
              • November 17, 2008
              • 348
              Marks left shield pic.(for r/h side) will not work with safety mounts, the slot holed brack is way too short, right shield pic. (for l/h side) will work with safety mounts as is, very similar to gm #3973402 (stamped #), comparing them to my 72 small block. There was a post reciently on how to change the shields for safety/non safety mounts and that bracket was not to be changed as I recall, the drilled holed bracket is the one to be modified. Was b/b the same as s/b ?????????
                Steven -
                Big-blocks didn't use V-shields - their plug wires came over the top of the valve covers.
                • Steven G.
                  • November 17, 2008
                  • 348
                  Look at Mark's left shield, there is a unused drill hole and the edge of that bracket looks rough... looks like it was modified !!!!!!!!! Changed from safety mounts to non safety??? Does anyone know how many different shields were made 63 and older ?? , 64 -72 used 4 that are different, that I have found so far. Also, does anyone have a pic. of 69 shields ??? Steve
                    • 43263
                    Steve-----
                    From what I can see of them, if these are modified 63-69 style shields, it's the best job of modifying I've ever seen.
                    With respect to the lower, inner shields that are the subject of this thread, there were 5 sets used over the 63-82 period:
                    63-69
                    70-74
                    75-79
                    80-81 (uses same left side as 75-79)
                    82 (I don't think any right side was used; left side same as 75-81)
                    • Steven G.
                      • November 17, 2008
                      • 348
                      I have known 64-67 and 70-72 lower shields, according to Joe's info., 63-69 and 70-74 their were 2 different types of shields for 63-74. After comparing my shields with Mark's, His shields have to be 75 or newer, they are not for 74 and older. I think the unused drill hole in bracket (l/h pic.) is the clue as to what shielding we are trying to identify. Steve
                      • Mark P.
                        • May 13, 2008
                        • 948
                        Steven - can you post a picture of the 70-72 shields. I would like to see the difference.
                        Mark
                        • Brad M.
                          • July 31, 2005
                          • 262
                          Joe,
                          I have a right side shield that I bought a while back which was NOS with GM sticker still on it and part number 14034993 which also has that extra hole, so I think his may not be modified.
                          You told me the following about this part number in previous post "correct lower v shield for 71?"
                          "GM #14034993 is a SERVICE-only part number for the RIGHT SIDE V-shield ASSEMBLY applicable to 1963-1979 Corvettes. As I mentioned previously, it's SERVICE only designation is the result of it including the reinforcements and attaching rivets. It is the "amalgamation" of the following 77-79 shield assembly components:
                          354423---SHIELD
                          3819766---SUPPORT
                          3973402----REINFORCEMENT
                          455624 OR ? -----RIVET (4)
                          GM #14034993 was released in January, 1983 and discontinued without supercession in November, 2000.
                          While it SERVICES 1963-79, it is not actually 100% correct for any year, although it very close to being correct for 77-79. It's fairly close for 70-76. It's usable for 63-69, but significantly different than the originals."
                          Steve, I would also be intersted to see pics of your known 70-72 shields.
                          • Brad M.
                            • July 31, 2005
                            • 262
                            by the way, i tried to post a pic of that shield, but the site seems to be blocking it and saying that it was previously attached to the previous post discussed above.
                            • Mark P.
                              • May 13, 2008
                              • 948
                              Here are photos of Steve's 1972 shielding.
                              Will these also work for a 1971 ?
