Best advice please as I have not done this before. I have the heads and intake off my L-36. I have borrowed a 8 ton engine lift. Obviously my 680 LB engine is lighter with heads and intake off...
What is the best, proper, safest procedure for attaching a chain to lift my engine out. What bolts, washers to use and where does one place the bolts not to damage anything....
Thank-YOu !!
Thank-YOu !!
