72 vac hose tee - NCRS Discussion Boards
72 vac hose tee
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 72 vac hose tee
    Ken,
    now that I know which application you needed it for here is a picture of it and yes all these wre 1/4" across the top and 1/16" on the leg.
    For those following this thread this is the fitting that supplys vaccum from the main line off the intake fitting to the Astro Ventilation/ heater control line that comes through the firewall and into the engine compartment.
    I don't know if they repro these or not. I took this off an original 69 435 many years ago.
    Rich
    • Rich P.
      • January 12, 2009
      • 1361
      Re: 72 vac hose tee
      OOPPS here is the picture.
      Rich
      • Bryan M.
        • April 1, 1999
        • 386
        #18
        Re: 72 vac hose tee
        Originally posted by Rich Pasqualone (49858)
        Ken,
        Rich
        The OP stated his car is a BB. Is this fitting big block specific?
        Thanks!
        • Rich P.
          • January 12, 2009
          • 1361
          #19
          Re: 72 vac hose tee
          Bryan,
          No this TEE is for all cars SB, BB A/C and Non A/C. In the 69 AIM you will find this under UPC1 Sheet M3.
          also on the 1/16" leg it uses the same 3 prong clamp that is used on the washer hose to wiper arm connection (AIM # 3891759)
          Rich
          • Bryan M.
            • April 1, 1999
            • 386
            #20
            Re: 72 vac hose tee
            Bryan,
            Rich
            I found it! But no clamp on it. I'll have to dig through my parts to see if I can find one.
              • 15637
              #21
              Re: 72 vac hose tee
              Not all cars had the clamp.
              • Rich P.
                • January 12, 2009
                • 1361
                #22
                Re: 72 vac hose tee
                Terry,
                I think you right it was a hit or miss with the clamp.
                Rich
                • Ken C.
                  • August 31, 2006
                  • 120
                  #23
                  Re: 72 vac hose tee
                  thanks Rich and Bryan, that is the tee i'm looking for. Only been 3+ yrs.
                  • Chris F.
                    • April 1, 2006
                    • 23
                    #24
                    Re: 72 vac hose tee
                    Hello Ken,
                    Was this the vacuum "T" I was asking about on the Corvette Forum.
                    I ended up making one out of copper tubing, then found a T at Corvette Central which is very close. It is off white in color however is as close as I think you will find. The part # is 303324 Vac Hose T-PCV Valve Emission Hose 70 - 73.
                    Best regards,
                    Chris
