...and yes I know how to spell Windshield but you can't edit the thread titles...
Hello All,
I had a chance yesterday to remove the stainless trim from the top and from of the windshield header on the 72 I'm working on. As an FYI you can reference the previous thread: https://www.forums.ncrs.org/showthre...66381&uid=4845
After removing the trim I vacuumed up the rust I saw and used an awl to pick away any scale. Thankfully it does not appear as bad as I thought it would. The driver's side is absolutely perfect. Here is a picture of the passenger's side, with the center of the car on the right side of the picture:
Some surface rust near the middle T-bar:
Right outer corner rust:
Underneath that same corner:
The worst rust is under the right front corner. I scraped it and picked at it, and then used the awl to try and poke through it from above and from below. I am not able to punch through the rust.
At this point since I do not seem to be able to show a loss of structural integrity I am tempted to remove as much rust as possible, paint it with Eastwood's rust paint, caulk and reassemble. I am not sure that I will gain much by removing the chromed right upper corner piece and investigating.
Does anyone else have thoughts on this?
Patrick
Hello All,
Patrick
